Power Steering HJ60 2H issues at low revs (1 Viewer)
Hampshire, UK
Hey everyone, sorry to bring up more Power Steering questions but I don't seem to be able to solve this despite trying lots of the great ideas on this forum! I have a 86 2H HJ60.
In summary the power steering is not working at low revs/when you’re not moving. i.e. parking, manoeuvring etc. It's VERY hard to get the wheels turning as it feels like the power steering pump is not assisting as it doesn’t have the revs to help. I have increased the idle and also had the pump rebuilt +new belt and then re tested and its still not a lot better. When the revs are there (when driving) its fine but I was wondering if there was a trick I’m missing here? I’ve been through the forums/YouTube etc 😊 Yes I know the tyres are bigger (33s) and this definitely isn't helping but there must be a solution.
- Fluid is ATF Dextron IID
- Flushed through 3 times
- Cold fluid level is bottom of hot mark on dip stick
- Front of truck lifted and wheel turned lock to lock to bleed (multiple times)
- I don't seem to have an idle up value for the power steering on this 2H (it seems some did and some didn't... maybe autos?)
- Belt tensioned (new tensioner pulley)
At the moment I've run out of ideas so any help would be appreciated.
- maybe I add an oversized pulley to the power steering pump?
Maybe there's something malfunctioning in the steering gear box
Maybe the pump pressure is low.
There is a way to check the pressure but it requires special tools. See attached pdf from the manual.
The manual states:
"If the difference of pump pressure at 1000 RPM vs 3000 RPM is excessive, (greater than 71psi/490kPa) repair or replace the flow control valve of the power steering pump."
Most of us end up replacing the pump.
Did you check the functionality of the flow control valve.
When this valve gets stuck in the bore you will have the issues you are experiencing.
My hj does this sometimes, does not get worse, a bit of rev and it catches up, not worse with front lokka locker but it has to work more for sure,
17" wheels (and I think anything above is to big, also with 5 speed towing 3500 kilogram trailer)
If you want an manual choke cable: attach it to the throttle, I bought 303078463201 - Venhill Choke Cable
Attach to pedal and you have more rpm, also possible at engine I think. Just push in throttle, pull cable and twist to lock.
But gearbox reverse is best with lowest rpm (650) because synchro mesh wont like reverse gear change and higher rpm.
1:45 flow control valve
12:40 installation
HI Sved, where is this located as I'm Googling and my truck doesn't seem to have this?
12:40 installation
Sorry for my lack of knowledge... but when I Google Flow Control Valve for the 2H Power Steering I get this... EBAY PART But in the video 1.45mins this is completely different and is a sprung valve built into the pump itself.
Both are flow valves for the Power Steering?
The valve can be stuck in the bore or the spring is to weak/ worn out .
HI Sved, thanks for your help. I'm trying to source a new Flow Control Valve and Compression Spring but there seem to be 6 options for the Valve... see here https://www.amayama.com/en/catalogs...ssis-2/vane-pump-reservoir-power-steering-130 4433060010 through to 4433060060 and my local Toyota dealer says the same. Any idea how to identify the one I need?
Separately the Compression Spring 9050112447 is no longer available (I will check my specs against your diagram to check I need one first) but on another post someone says that 9050112103 can be used instead... again sorry, but do you know if this is true? I have a history or ordering the wrong parts :)
The valve and the housing are matched with a mark A to F
Spring should be ok to reuse.
Hi Sved
After some swearing and some bruised knuckles (on the hottest day of the year :) ) I have the valve out. BUT to my dismay it has a B and a C in the casting. See the image for these. Do you know which it is? The B is next to the where the valve came out.
and
Which marking does the valve have ?
Was the valve stuck or loose in the bore ?
If I remember correctly there should be a mark on the machined side of the pump. You first picture on the left side ,which can not be seen in that picture.
I understand you took the valve out from the bottom.
If you mount it back and take of the top hose then you can test the valve by slowly pushing it down into the bore .it should return easily without binding. If it binds you can give it a twist with a screwdriver and see if it loosens.
