power steerig pump question - manafree alu. pulley
orangefj45
Supporting Vendor
norcal
first off, let me start by saying that i have searched and made quite a few phone calls, even to manafre and they were'nt able to help. second, i'm not so sure that this is necessarily hardcore but the newbs in the 40 forum would'nt know the answer to this either.....
so here goes: i'm helping a buddy with a ps conversion on a cruiser with a stock 6 banger. he got the ps pump mounting bracket thru me from AA. same as BTB, 4+,.... and he got a manafre aluminum pulley for the pump to run the wider belt. the problem is that most pumps use a press-on pulley with a .750" diameter shaft. the pulley we got from manafre has a keyed .625" diameter shaft. and we can't seem to find the proper pump locally.
i did talk to steve-o at manafre and he was very helpful and professional as usual but he could not tell me the proper application either. manafre does offer the pump for $140something. i'm trying to find one locally.
so here's the question:
does anybody know the application or a part # for the pump required to run the manafre pulley?!
just to make this a little more fun, i'll send the person with the correct response a little trinket!:beer:
I did my conversion a while back and bought my pump/hoses off the shelf at a yard, no #'s, works perfect! Fast forward. Dont let your friends drive your Cruiser after such mod- you'll be doing theirs soon. So I start collecting parts to do my friends conversion... start looking for the same pump as mine...online, yards, catalogs, under hoods, everywhere? All to no avail. Finally one day the stars are aligned and find one that *will work* but needed hoses/or hose end and bolts. I go to look at their stockpile and one tries to stab me in the eye! pump/hoses/all bolts/stock bracket and all! It looks to be the EXACT same as mine! WOO HOO!
I am sure there are several that would *fit* the bill. What I really liked was the shape of the tank, if you are retaining the stock later air cleaner, and using the said bracket (4+,ect.) it allows for decent clearance and a stockish appearance- see pics
Not sure if different GM pumps had different pressures but... mine is awsome, I have a GM pump with a '84 60 box, 4+ bracket, MAF alum. pully, and custom hoses, no cooler yet.
Anyway, when I bought the second pump fourtunetly it had a tag on it, I finally found out the application if ever needed:bounce:
It is off of a ...
Just playn :p Its off of a '69 Nova. Obviously there will be a nut on the front of the pulley as well as a keyway, NOT the allen head! The neck is also rounded, not squared.
Is a Orion considered a "trinket"? :D
Thanks for the offer, I am just happy to pass on some info- as you have all done for me:cheers:
thanks for the info hicruise55. i'm going to get a pump for a 69 nova today to see if that works.
please pm me your full name and addy and i'll get a little something in the mail to you. :cheers:
i'll pm you. thanks for the link! :)
