Since I am still bearing the scars from replacing the antenna assembly on my 80, I agree with the point toward the end of Steve's checklist that a good place to check is for corrosion where it has the pointy contacts to ground on the fender. These are prone to corrosion of the zinc-alloy casting, which would definitely account for many of the symptoms that people mention.
If someone had ever attempted to fish the coax through in replacing the antenna assembly, there is the potential for cutting the coax. Done right, it won't happen, but it's tight back there. Not one of Mr. T's better days when that passageway was designed, but I'll take it with all the other GOOD stuff
Mike
Mike
My wife has a MS in ECE. Between us, we mostly get things figured out when we need to, but only after at least some mild befuddlement.
