- Thread starter
- #21
1/2" brass drift on Amazon...$10.50
http://www.amazon.com/Mayhew-25076-2-Inch-Knurled-Brass/dp/B002XMSBBI/?tag=ihco-20
Thanks dan! Done!
Do you happen to have a wider shot of this pic so i can reference where exactly the fitting sits? If you have that parts list, i'd definitely appreciate it.
The front diff fitting should mount on the flat spot on the front cover as shown in the ARB install guide. Since its IFS and has skid etc there's not much worry of snagging on things. That said, we stock and generally recomend the stainless lines, as they are more resistant to abrasion and heat.
Front cover, that's what I was thinking, my ARB must have been installed correctly then when JT's did it! It is an easy straight run when done the way ARB recommends. I could see where the installer would find it easier to rout through the steel case vs. the aluminum cover though.
Nice to know. Thanks. The only problem i have now is trying to get the front diff and 3rd member packaged. I thought it would fit into a 5 gallon bucket, but it turns out that both pieces are a bit too long. What did you guys do?
