alia176
Does anyone know if there's an adapter that can be used to turn a shaft using a typical pipe threader? In another words, instead of turning a die for cutting new threads on a pipe, I'd like to turn a 5/8" keyed shaft to turn a sprocket.
Here's what I got: Portable Electric Pipe Threader
I'd like to weld a 5/8" keyed shaft to the center of this adapter so that this machine can rotate a shaft which will in turn rotate a sprocket.
I see that Rigid has a square bore adapter, so it's along the same line but I need a 5/8" circular hole for a 5/8" shaft Ridgid Square Drive Adapter For 1AC02, 15/16 In 42620 | Zoro.com
I suppose I can sacrifice the 1/2" pipe threading die and somehow weld a 5/8" shaft to it but was hoping to avoid that!
