Pinion flange bolt pattern (2 Viewers)
Sandy Utah area
Anybody know the rear pinion flange bolt patter for a 97? I measured 3.55 inches (90mm) square but that is way too big based on wha i can find online. The front seems to be right at 60mm square. Any help?
It looks like 2.55 inches, not 3.55.
Quick check on a spare driveshaft this morning. Kind of an eyeball caliper job but really close.
My guess is that my eyeball job is off a smidge making the centers 65mm. I can't imagine the dimension going into decimal places from there. It is a square pattern too, which you probably already know. Hope it helps.
Edge to edge distance will be the same as ctr to ctr..... just sayin, a lot easier to eyeball that way
Or use Kurts cheat sheet ;)
66x66x11
Cruiser Outfitters
Which doesnt quite cover 80s but his catalogue has some clues
