Kaderabek
GOLD Star
Did the PHH this weekend. It's not that bad. Took the advice of Jim Reiss, pulled the wheel, starter and transmission dipstick tube first. Getting to the hose is straightforward after that. Cut the hose in half, pulled the cotter pin on the outside clamp, removed the clamp and that half of the hose. Cut the other clamp off with a Dremel tool. Mostly. Loosened it up enough anyway, then hacked a piece of the hose out and grabbed the clamp with my needle nose pliers (actually my daughter's, came out of her beading kit when I couldn't find mine). Later remembered to pull the other half of the hose off.... It's dark back there! Soaped the inside of the new hose and put it and both the new clamps loose on the outer side. Then began to try to rotate the down tube and new hose onto the nipple on the engine block. Tried a lot. Tried many ways. Wouldn't do it. So had lunch and got some brain power back. Put the new hose/clamps on the engine block nipple and began the process again. Steve Smith (who is a saint) then muscled the down tube into place from the top and I clamped her down. Refilled the radiator, put the rest back together and we were done.
Took 7 hours, give or take. It would take 3-4 to do it again. Knowing how to rotate that down tube is the key. The rest of it is easy.
As usual, my hat is off. To Jim Reiss for the good advice. And to Steve Smith who arrived at 8 am and was essential to the process. You all are good friends and in many ways that's what this is all about.
TJK
TJK
