Many reasons that are all previously mentioned.
Seems to me that you need to spend a bucket load of money on a 6 cylinder to come near a V8. The V8 leaves a dt/ft/ fte behind as a 1HDT does to a 2H turbo
Seems to me that you need to spend a bucket load of money on a 6 cylinder to come near a V8. The V8 leaves a dt/ft/ fte behind as a 1HDT does to a 2H turbo![]()
Yes I get that point however I am not aware of his budget yet. Maybe I missed that.And then V8 guys have to spend a bucket load of money to try and catch the dt/ft/fte's. You have to spend money on any engine diesel engine to get it to go well.
This is where i may have to get some help regarding the Toyota product line in question. But low injection pressures are typically 1500PSI - 2500psi or so. the 2h is low pressure for sure. I believe the 1hz and 1hd are also low injection pressure and Indirect injection (commonly these go together i believe). High injection pressures like 15000 - 35000psi are typical in modern pumpe duse and common rail direct injection diesel models. I think Toyota’s equivalent to this is the 1KD-FTV engine.
Bio Diesel is just the end product of a process that removes waxes and "thickness" or viscosity from Veggi oils and other BIO based oils, soy etc. Its done so that there is a better match between the bio fuel and the diesel fuel which the engine was designed for. Specifically the fuel delivery systems on various vehicles. Even then, long term, there are issues with seals, tank walls etc that can be seen. Again lots and lots of mitigation steps are out there to avoid these risks.
It still won't get the low end back. So just don't touch that part. But your on the right track. Intake manifold mod makes up for a fair bit. This can only be done on the DT's. the FT's can't as the injector lines run over the manifold.
How about one of the Diesels used in the Isuzu trucks? They seem to be popping up here in the US in some Land Cruiser Diesel conversions, and are relatively inexpensive. I would think you could get some decent power from their 5.7 and 6.3 Litre six cylinder TDs.
http://en.wikipedia.org/wiki/List_of_Isuzu_engines
The 6BD1T is a 6-cylinder version of the 4BD1T and displaces 5.7 litres.
The 6BG1T is a 6-cylinder version of the 4BG1T and displaces 6.3 litres.
The 6HK1 is a SOHC 24V turbocharged engine with 200-300 HP (149-224 KW) and 700–1,160 N·m (520–860 lb·ft) of torque.
Wheeled with two Diesel conversions at Moab this year, one a Cummins, another an Isuzu. The Isuzu definitely was much more refined and seemed to produce very usable power...the Cummins made plenty of power, but definitely was more of a brute (and noisy).
Steve
The Isuzu motors are very reliable, and I reckon have plenty of power potential. But the problem is they're big, I reckon you'd struggle to fit the 6b motors in a cruiser or patrol while keeping the radiator in there. The 6h motors are bigger again.
Hey User Name, (thats an odd username btw), Im guessing that the list has narrowed down to the cummins, awesometacular toyota 12ht/1hd-t/1hd-ft, and the missan td42 soot blower.
If living in the states the cummins would prolly have to be the best choise due to availability, parts, price etc. but since you are here in straya the latter two brands would have to be the easiest to get a hold of.
Question, will you be wanting intercooling? If so air/air or water/air? I know a fella on this forum that makes a very efficient pie warmer for the tojo
There is also another aussie member called gbentink that has a lot of info on the 12ht and the mods available, (injector pump, turbo, boring and stroking, running on veggie oil etc) he is a true hacker that would be your best bet to send a p.m. to.
Here is a pic of my injector lines over the intake manifold to show why increasing capacity would be prohibitive, unless you know of someone who could make up new injector lines for the right price? I would be first in line for a set.
Yep, if staying local the toyo's and TD42 are top of the list. Funnily enough the cummins looks like it will be cheaper even after import. Will definitely want to be intercooling.
With the injector lines over the manifold, is it not possible for you guys to move them?
PS. What's a pie warmer?
You won't get a cummins past Australian emissions standards. Why would you fit a TD42?
6B into cruisers has been done several times to my knowledge.
Why wouldn't I fit a TD42? They are readily available if I chose to use them and can get some descent figures..
A bit off topic I know, but found a pic of a cummins drag racer apparently running 100 psi boost with 2500 hp
Not many people would be wanting a td42 in their cruiser I'm thinking...
