Na, he can just wait until its all released.
"Red herring brigade,, Asssseeeemmmmbbbllleeee" in Ron Bergendy voice.![]()
TOO FUNNY!!!
TOO FUNNY!!!
77cruiser77 said:This I find interesting seeing how I am in the process of collecting my parts to begin a turbo and intercooler install into my 1HZ. At the same time I'm also exploring WVO for my vehicle too.
The 12HT from what I have heard can go up to 5L. This does require a lot of money to do however. Problem with that engine is it was produced for a short period, (1985-1990?), parts are both hard to get and expensive, and is direct injection which from my understanding isn't preferred. It is a brilliant engine with timing gears instead of belts and chains, inline pump, and direct injection.
77cruiser77 said:A lot of people play with the 3B because even though they are dated they are tough and plentiful. They are also indirect injection and most have an inline pump instead of a rotary one. They are 4 cylinder and 3.4L. The direct injection turbo version of this engine is the 13BT.
77cruiser77 said:There is the 2H also which is the non turbo indirect injection version of the 12HT. If you want performance I have read its not the best engine due to piston cooling.
77cruiser77 said:The engines people are beginning to really play with now are the ones produced post 1990. There is the 1HZ, a 4.2L inline six indirect injection diesel engine with a rotary pump. Production on this engine started in 1990 and the last one made would have been yesterday, assuming it was a work day, and the next one will be made on the following work day until something better comes along. This would be an excellent candidate to me seeing the availability of parts on a global scale including Canada and US, and information due to it being made for nearly 25 years with only minor changes being made.
There is a turbocharged direct injection version of the 1HZ which is the 1HD-T. A variant of this is the 1HD-FT and also the 1HD-FTE. The FT has 24 valves instead of 12 while the FTE has both electronically controlled injection pump and 24 valves. There are a whole bunch of other differences between the 1HD-T, 1HD-FT, 1HD-FTE but what I mentioned are the major ones. All of these were not produced for nearly as long as the 1HZ which might be something to consider.
I cannot comment on non-Toyota engines but Nissan has a diesel TD42 that is very similar to the 1HZ. People seem to get impressive results out of it and depending on you location perhaps something to look at even if only for ideas.
Douglas S said:Direct injection is preferred for a performance diesel (or any diesel really).
o8ko8k said:this is a thought provoking thread. ill chip in 2 cents.
SVO:
1.Viscosity vs temperature curve is different from that of diesel fuel
2. Contains waxes that are not present in Diesel fuel
3. Slightly lower energy content that Diesel fuel
4. NOT made from Petroleum
5. Poses reduced engine reliability (which can be mitigated very well if done correctly)
High injection pressure injection pumps (HIP)
1. Matching viscosity with alternative fuels like SVO is harder than with Low injection pressure pumps
2. Great performance gains and fuel economy can be had from these systems
3. Matching viscosity IS important (see reliability above)
Low injection pressure Injection Pumps (LIP)
1. Has a wider range of allowed fuel viscosities thus, achieving a match with SVO for an engine which was designed for Diesel fuel is easier.
2. Performance and fuel economy take a hit too. combustion isnt as complete, air/fuel charge is more stratified, etc.
SOOOO...
with that stuff on my mind. do you go HIP or LIP with SVO when your goal is performance? 3 more things come to mind
1. How much money are we talking about here?
2. Is this thing going to be raced? (e.g. does the engine need to last longer than 1 or 2 races?)
3. WIll this be someone's daily driver?
As far as a diesel that is the mainstay of diesels, i would look nowhere else than the Cummins for that IMHO.. SNIP
Tapage said:ok .. grab your fav beverage and start reading ..
https://forum.ih8mud.com/diesel-tec...4-volts-systems/diesel-tech-...fications.html
https://forum.ih8mud.com/diesel-tec...4-volts-systems/diesel-tech-...ng-thread.html
https://forum.ih8mud.com/diesel-tec...4-volts-systems/diesel-tech-...od-thread.html
and here ..
https://forum.ih8mud.com/diesel-tec...4-volts-systems/diesel-tech-...rformance.html
ForealBoreal said:-Snipped (as above)-
Guys do crazy 200rwkw Nissan GQs with an turbo'd IDI diesel. They can take the abuse if your egts are in check. I'll be putting 20lbs into my 1hz sometime this year.
Hulsty said:If you have $$$ to burn and import engine is a good option too, cummins, duramax etc 500HP +, may be worth looking into truck engines too, stuff like Isuzu's are pretty common in Australia.
As previously mentioned if going SVO or alternative fuels I think the preference is indirect injection and inline injector pumps since they are more robust to this fuel setup and do not rely on the fuel for their lubrication. The TD42 can be had with inline fuel pump and is indirect injection.
BEE-JAY42 said:To summaries, old performance diesels don't really exist, the best power you will find is from the newest engines.
What mods are giving these results? Any experimenting with internals?TheBigBoy said:I have a diesel performance business and 300rwhp and 800nm is available from the DT/FT/FTE and so on.
mudbludger said:User Name are you thinking of something like this?
http://www.speedhunters.com/2013/06/...sel-chevy-rod/
wrongway around said:Plus when you start getting over board in the r&d hope you have some engineering background.
Ive played with internals. But there is really no need. Mostly its all bolt on. Snorkel, airbox, Gturbo, Intercooler, injector pump, injectors, dump, exhaust and clutch.
Ballanced the crank and port and polished. Increased it alot on the flow bench. But being diesels you cant grind the internal radius of the intake or exhaust runners. You will lose all your low down torque. So increase the bowl around the valves and polishing the hell out of it is all you can really do. Ofcourse you can play with duration of the valves. But I see no need at all. They go GREAT.
Its been done before in the past, and thats the result. Welcome to the world of diesels.
Why waste money on old technology modifying, just start with the Cruiser V8 diesel.
How about one of the Diesels used in the Isuzu trucks? They seem to be popping up here in the US in some Land Cruiser Diesel conversions, and are relatively inexpensive. I would think you could get some decent power from their 5.7 and 6.3 Litre six cylinder TDs.
http://en.wikipedia.org/wiki/List_of_Isuzu_engines
The 6BD1T is a 6-cylinder version of the 4BD1T and displaces 5.7 litres.
The 6BG1T is a 6-cylinder version of the 4BG1T and displaces 6.3 litres.
The 6HK1 is a SOHC 24V turbocharged engine with 200-300 HP (149-224 KW) and 700–1,160 N·m (520–860 lb·ft) of torque.
Wheeled with two Diesel conversions at Moab this year, one a Cummins, another an Isuzu. The Isuzu definitely was much more refined and seemed to produce very usable power...the Cummins made plenty of power, but definitely was more of a brute (and noisy).
Steve
Interesting. I've been reading and from what I can find it's the velocity/swirl in which the air enters that makes for the low end torque. Couldn't a turbo and upgraded plenum be used to compensate for any loss of velocity if you were to port the intake?
Seems to be for SVO/Bio that IDI is preferred, though I really think there's more that can be done with the fuels delivery and something a buddy and I are talking a lot about lately and getting ready to experiment with.
Thought provoking response! I should mention here that I will soon have the capability of making Bio, and as needed Bio and SVO could be substituted depending on vehicle setup.
To answer the 3 questions;
1. With doing most of the work myself, I would like to keep engines between 10-15k as a baseline, or as close as possible. Obviously if we're talking business sense and a customer had available income to spend, then I would be happy to build engines suited to their budget.
2. None of my personal engines will currently be raced.
3. My personal vehicles and I would assume hypothetical customer vehicles would be daily/weekend cars. I have a couple builds in mind for buddies who would be driving the vehicles daily, in which high figures would be less of a concern and fuel efficiency would more so.
With LIP and HIP's, are there any general associations with the IP's and engines? ie. HIP's being used with electronic or DI/LIP with mechanical or IDI? How do you think HIP would handle Bio over SVO? SVO blends?
What sort of pressure figure differences are we talking between LIP/HIP with some of the engines mentioned in this thread?
I'm putting a lot of energy into my SVO heating system on board and when the oil is hot and properly filtered, it does have quite a low viscosity, when blended 5% with ULP or another blend it becomes very close to diesel in fluidity at ambient temperature.
