PCV Hose Routing
Santa Fe, NM
Just finished a 2f swap in an 84 '60. All good, but spaced marking the PCV hoses? Am looking for the hose coming off the "T" above the PCV? Looks like it routed back into the cab through the firewall...but that seems like a BAD idea...
Any and all help appreciated!
The small hose on the branch of the tee goes to the HIC valve which is a temperature valve mounted in the bottom of the air cleaner. The large hose on the through branch of the tee routes around the back of the air cleaner and connects to the intake manifold below the carb. It's the rearward port on the EGR inlet.
Thanks
Got it...I have always trusted my handy vacum diagram on the fender well, but clearly something is amiss. It shows the firewall side vac port on the dist. going to the HIC? I suspect this heads to the firewall and the hose I am chasing goes to the HIC? Will give it a whirl in the am...
Thanks
