- Year
- 2007
- Vehicle Model
- 100 Series
- Location
- Pascagoula, Mississippi United States
- Mileage
- 203000
- Color
- Gray
Purchased from a fellow mudder in Feb. 2020, sold to a fellow mudder in March of 2021 and then bought back from same mudder in August 2023. I bought it the first time for myself to have as a daily, sold it because I was traveling too much and didn't want to put the miles on it, and then bought it back as an option for a nephew to drive back and forth to high school. He doesn't want it and I don't have the space for it so it's time to let it go. Here are the details:
- 203,xxx miles and will likely stay around that. It is garage kept and driven only on the weekends
- Toyo Open Country AT3's 275/70 R18 that I have driven 4,000 miles on
- Grom Audio new VL2 Infotainment System w/wireless Apple Carplay and Android Auto and enhanced speakerphone capabilities
-Ceramic window tint on every window (20% on six side windows and back window, 35% on front windshield)
-Replaced timing belt/water pump/thermostat
-FULLY baselined. Replaced all fluids including power steering and transmission.
-Full aluminum Mishimoto radiator
-New tie rod ends
-New upper and lower ball joints
-New hood and tailgate struts
-New PCV valve
-Delta panhard drop bracket
-New sway bar end links & bushings front & back
-Brass heater Tee
-Ironman Foam Cell Pro shocks all around
-Ironman Springs (light duty 0-440 lbs)
-Ironman Torsion Bars
-Diff drop
-White Knuckle Off Road sliders.
-New battery
-Installed Fumoto oil valve (easy drain)
-OEM fuel filter
-OEM gas cap
-Spidertrax 1.25” spacers (Torqued and re-torqued)
-OWL Expedition mud flaps
-POR15 entire underside (as preventative. The one spot that is notoriously bad for the 100 series in the back crossmember which had a small piece rusted out. Had someone cut it out and weld in a new piece. Strictly cosmetic. But had me worried so I POR 15 it. Anyone can take a hammer to the underside. No worries. Not rusted.
-New foam for front speakers
-Replaced back subwoofer with a Skar subwoofer
-New OEM front grill
-New back Land Cruiser badge
-OEM tail light replacements
-OEM hood to cowl rubber
-OEM hood to radiator rubber
-Spoiler clear coat is peeling (see photo)
- Right side mirror arm needs refinishing
- Windshield has a crack across the bottom, out of sight line (see photo)
Asking $25,500
-New tie rod ends
-New PCV valve
-Brass heater Tee
-Diff drop
-New battery
-OEM fuel filter
-OEM gas cap
Asking $25,500
