Parts for Injector R&R, 1HD-T 08/90
Japan
Website
projectpursuitmedia.com
Greetings,
Getting ready to pull my injectors and send off for rebuild, below are the parts I am tracking to replace while in there. Am I missing anything that you all see off the bat? 08/1990 model, 1HD-T.
Injector O-rings96711240196
Injector Seats11176170106
Injector Washer90209220066
Glow Connector19871170211
Glow Grommet90189040246
Not sure I need the glow connector, but mine looks like dog****.
Going to send them to Diesel Fuel Injector Services in Portland OR, unless anyone has a recommendation otherwise. They are charging $45 per, plus any parts needed.
Thanks,
Clay
From the FSM, which is in the resources section of the main Forum menu.
The black diamond beside the part means it's single use
Yup, that is what I got, my nomenclatures are just copied from Partsouq... was just wondering if there were more "while you're in there, you should replace this" type of items.
Rubber fuel hose from the leakage/spill pile, back to the hard line that goes back to the tank
Is that something needs to be ordered specific? OR will generic fuel line from the parts store work?
Here is the list of what I ended up ordering. There is a lot of leakage coming from the plenum mating area in general, as well as corrosion on some of the bolts/nuts, so I ordered certainly more than bare min. Many of these are specific to the early 90/91 models.
NOMENP/NQTY
Injector Bolt90105102926
Manifold Gasket 117171170101
Manifold Gasket 217179170105
Manifold seal washer902100804112
Manifold seal nut901790804012
Bolt, Manifold crossover90105082272
Fuel Return Hose95333040201
Fuel Hose Clamps90467101496
Hose holder90464004131
Boost hose, gen90999920071
clamps, vacuum90467070166
