Parting out 1991 FJ80
Austin
Website
www.cruiseryard.com
Best way to contact me is jason at cruiseryard {dot} com. I am also parting out 3 other 80s, a 93, 94 and 95.
Parting out 91 FJ80. Tranny needs to be replaced.
The 3FE was rebuilt about 60K by a PO. I dont know anything more than that. It is currently in the truck and can be heard/driven. It runs good. Would be good for a 40 conversion Since no one bought the FJ80, I have decided to part out it out. Engine is $600. Harness and ECU are $200
Body parts are rust free, but paint does show clear coat problems. So some body parts would need to be painted to be perfect But again, they are very solid.
Interior seats are very good condition. 1991 Land Cruiser - a set on Flickr
Some parts are below-
Front drive shaft
Rear drive shaft
Master Cylinder
Brake booster
seatbelts
Headlight
Turn signals Front (below HL)
Parking/Corner lights signal, next to HL
PS Rear taillight
AC Compressor with clutch
Center Consolse
Center Console cup holder, DS
Driver pedal covers
Antenna motor
Rear wiper assembly
DS Rear panel in cargo area, covers toolkit
Digital Clock Bezel
Front half of carpet, 1st and second row
Cargo carpet
Front Grill with Toyota
Front Seats
Hitch
Rear lower tailgate, comes with nice carpet panel
Rear upper tailgate - has a couple of dents on it that could be fixed, see pic. Comes with glass and emblems
headlight/turn signal switch (left side)
cruise/wiper switch (right side)
center dome light
starter
ECT switch
Rear Defroster switch
Rear Heater switch
Antenna switch
Hazard swiitch
Dash light dimmer switch
Mirror Adjustment switch
Tool bag
Rear Heater
Brackets for 3rd Row seats, these attach to the wheel wells
ABS Speed Sensor, DS and PS available
Ashtray
Fuse cover, below dimmer, black in color
Speedometer Sensor, part 83181-20040
Heat and AC controller
Rear Heater hoses, hard lines, set of 2 (http://www.sor.com/sor/cat188b.tam?xax=31963)
Air Flow Sensor
Transmission cooler
Hood Gas Struts
Rear Door lock actuator
Front Door lock actuator, comes with lock assembly and electrical connections, cant separate
Gas struts for hood
Radiator
Fan shroud
Windshield Wiper Reservoir with motor
AC Dryer
Evaporator
Condensor
Hi pressure line (compressor to evaporator)
Low pressure line (compressor to condensor)
Alternator
Front Flares
Rear Door flares
Rear quarter flares
Valance
Front 3rd member only
Hood
fender
Muffler
Cat
tail pipe (goes over rear axle)
Interested in:
Power steering pump if working and not leaking
Front bumper corners
To 98109
Thanks!
PS pump is broken. The corners will be sold with the bumper, which is $150.
Looking for the main fuse box bracket from a '91.
Toyota part # 82615-60010
This is the one that holds the main fuse box to the inner fender, pictured below.
How much shipped to 92102?
I will follow up with an e-mail.
(pics borrowed from Landtanks thread)
more pics uploaded to flickr- see link in post 1
I added more pics and a video of the engine
part wanted
like to have the body,frame,axles,shafts,tranfer.,fenders,hood,front end,and steering..don't need motor,doors,rear lift gate&tail gate,striped inside,no seats,or dash ,If these's parts are for sale Pm Me.
pm sent
Austin
Would you be willing to ship the gas hood struts to Canada if they're still available?
They are not good. They last about a minute and then the hood falls.
You have a email, but after further inspection of the pictures it appears that a couple of the things I asked about are either missing or cracked, but let me know whatcha think on the rest.
Thanks,
Tucker
Is everything on the truck original? Mainly the engine components
