SOLD Parting 7 80s, lockers, 3FE, LXs, CE. lots of parts and always changing
WOW, tanx for the quick response. however I believe the running boards I have are off of a 93+ the brackets that came with them won't work due to the vertical 90 degree angle, the brackets I need are angled back (roughly 75-80 degrees) under the rockers, no hurry but if you'd like to check under the one ya have & see if those brackets are angled, Please lmk? Tanx again. P.S. the correct mounting bolts thru the brackets into the body would also be nice ta have ???
The only 91-92 I have didn't come with them so I wouldn't have a set. Sorry man.
Hi, total noobie here. I picked up someones else's project 80... and their significant other threw away a bunch of the plastic trim when the interior removed.:eek: Anyways, I am looking for A, B, C and D pillar plastic trim, top to bottom, in Tan. I also need the rubber door seals. Any help is appreciated. I also live in South Atlanta, so I wont need shipping;)
not sure if you can send messages with only 1 post so i will post here.
what year did you get and is it a lexus or cruiser? might be best to call or text me since you are semi local. 478 six09 0seven87
hey are you looking to sell the cab shells all in one piece or would you cut me some out of the wheel arch/sill?
I'm looking for a front differential/3rd member. open is fine. do you have one that is in good shape? How much?
Do you have a drivers and middle 2nd row seat belt in oak/brown?
Clean dash in same?
Thanks
looking for a steering box
Hi I need the harness side of the neutral safety switch connector for my 94 80 , any to sell?
Thanks
Is the 1991 interior brown? I need a good dark brown master window switch cover for my 1991 FJ80 dark brown interior.
Thank,
RKTINC
