Part numbers for Timing Belt Job with Hose Refresh and a few other tidbits 2004 GX470 178,000 miles (1 Viewer)
outer space
Second time around doing a timing belt on a 2004 GX470. I wanted to get the part numbers down here because it's a PITA to get all the correct numbers...
I always try to refresh hoses and clamps with OEM when they are this old just so I don't get surprised by one blowing later on. I love knowing I don't have to worry. I also put in new brush set into the alternator while most stuff is out of the way. Cheap insurance, they have about 25% or less left at this point in both vehicles. I also change out the cam and crank seal at this age, again cheap insurance for no leaks down the road.
I'll add more of what references and tools I used, and issues I may have run into performing the TB change. It's a fairly easy job to do, but can be time-consuming if you haven't done it before, and care about cleaning everything, when it's a s*** show in there after months of leaking coolant from a torn o-ring at the inlet that the last guy did poorly. Somehow it lasted for 50-70K.
FROM AMAZON:
FROM MY LOCAL DEALER PURCHASED USING ONLINE PARTS STORE FOR DISCOUNT AND FREE SHIPPING:
Hoses I replace around 2nd TB change:
  • 16572-50190 bottom radiator coolant hose qty 1 @ $32.80 #2 hose
  • 90466-41008 hose clamp qty 2 @ $7.36 clamps for bottom hose #2
  • 16571-50200 top radiator coolant hose qty 1 @ $29.75 #1 hose
  • 90466-41008 Radiator hose clamp qty 2 @ $10.21 clamps for top hose #1
  • 16295-50070 Engine coolant hose qty 1 @ $7.83 #7 from throttle body to rigid oil cooler pipe
  • 16261-50090 water bypass hose qty 1 @ $7.83 from throttle body to crossover
  • 96135-51300 bypass hose clamps qty 4 @ $3.39 2 for hose #7 and 2 for 50090
  • 16281-50030 engine coolant hose qty 1 @ $11.60 water bypass #4 from t-stat to rigid oil cooler pipe
  • 15777-50060 hose, oil cooler qty 1 @ $20.93 this one might be harder to get to under the engine, do later
  • 16282-0F010 engine coolant hose qty 1 @ $8.89 water bypass #5 from rigid oil cooler pipe to oil cooler (previous part number 16282-50070)
  • 90467-20011 clips (clamps for the cooler hoses) qty 6 @ $3.78
    • 2 Needed for 15777-50060; 2 needed for 16282-0F010; and 2 needed for 16281-50030
Extra Gaskets & Seals I like to purchase:
  • 16341-50020 Gasket, Water Outlet - coolant cross over pipe gasket qty2 @ $10.93 (previously had leak on bumper side of engine, pass side, buy 2 to have on hand)
  • 96761-35035 coolant pipe o-ring qty 1 @ $4.31 (came with timing belt kit, didn't need, but get just in case it gets torn. It goes over small inlet pipe for water pump)
  • 90311-A0001 Type T oil seal qty1 @ $14.20 (crankshaft seal, easy to replace with screw driven into seal , or Lisle tool)
    • Don't let them give you the "shaft seal" or "oil seal" it won't be the correct part number…
  • 90311-38065 Cam Seals qty2 @ $21.98 I highly recommend getting a spare for when you roll one of these putting them in
Alternator:
  • 27370-20130 Brush Holder qty1 @ $22.65 easy to change at 180,000 miles it needs changing
  • 90068-10142 qty1 @ $26.98 drive end frame bearing
  • 90099-10140 qty1 @ $30 rear bearing
Coolant:
  • 00272-SLLC2 super long pink antifreeze qty2 @ $23.95
Air Filter:
  • 17801-50040 engine air filter qty 1 @ $21.24
Serpentine Belt & Tensioner:
  • 90916-02586 qty 1 @ $51.31
  • 16620-0W101 V-Ribbed Belt Tensioner Assembly qty1 @ $82.66 (bad bearings should be replaced ea TB change, or at least after 100,000 miles)
Other part numbers I've needed:
  • 90342-10021 trans plug qty1 @ $3.35 (during tranny oil changes these can become messed up. I like to have one on hand
  • 22271-50042 throttle body gasket qty 1 @ $27.75 (didn’t need this)
  • 90080-91180 spark plugs qty 8 @ $9.99
FROM AMAZON:
Alternator:
Coolant:
Air Filter:
Great information! Thanks!
