Part Number Request: Rocker Drain Plugs
Dallas, TX
Hey all - first post but longtime lurker. I have a pretty clean, bonestock, grandpappy spec '97 FZJ80 and finally heard that fun sloshing sound after a good rain. I've cleared out the drains in the pinch seams and pulled the rocker plugs as well just to let everything dry out extra well. Unfortunately, my plugs are pretty dried out and crusty and thought it'd be worth dropping new ones in given they're probably dirt cheap.
For the life of me I cannot find a part number for those (tried searching here and elsewhere). Could be using the wrong keywords or names. Anyone got a line on this?
Thanks so much!
There are two sizes:
90950-01398 (large) and 90333-20001 (small)
IIRC, the larger ones are also the floor plugs.
Well, crap. I really have to have a talk with my admin people.
90950-01557 is the interior floor plug. My memory is failing me.
If my notes are correct, 90950-01182 is the rocker panel large plug and the smaller ones are the 90950-01398.
So many parts, so little time.
@wjbb : are referring to the rubber plugs on the back/inner aspect of the rocker panels?
Using Partsouq dot com (enter your VIN first) you can find the rocker panel plugs under Body/Interior in their system then scroll down until you locate the group of parts you're looking for (Front Floor panel in this example). Or you can try a wide search using their Search function but IME it's a bit quicker to first start with the correct Group if you know that (or pick from the listed options).
Note next to the part number 90950-01882 (6) is a number in parenthesis, this indicates how many plugs of that type are required if replacing them all:
FWIW
Larger rubber plug (mentioned in post #5) located on the back/inner aspect of the rocker panels:
If you go to Partsouq and look at the diagram above you'll find a few different size/type body plugs and decals (plastic stickers used to cover holes).
Thanks all so much for the help. Will use partsouq in the future. I believe it's the smaller plug that @Malleus mentioned (picture of the ones I pulled attached which I should've done initially). They're about 3/4" in diameter (the actual hole being about 1/2") and hard black plastic. There are four on the direct underside of each rocker. My passenger siderocker pissed about half a gallon of water out of one when I pulled it.
I mistakenly bought the larger rubber one mentioned, which is what led me to make the post. Anyways, many thanks to everyone for the help.
@wjbb : this is the smaller plastic hole plug found on the bottom of the rocker panel. FWIW to remove without
damaging the paint I use a pair of needle nose pliers and grab the small center section (not the whole thing), then wiggle, twist, pull. IME/IMO they should be replaced due to age/shrinkage/damage.
It's found in a few locations:
