Yes, a short.
All the lamps you listed are part of the "tail" fuse circuit.
Somehow, voltage directly from the battery is now present on this circuit, downstream of the fuse.
That relay that you pulled, was it in a socket? If so, was it intact?
Did you get a good look at all the aftermarket wiring?
Despite what you disconnected, some elements of it are probably remaining.
Also, the "light retainer" relay is upstream of the "tail" fuse/lamp circuit.
