Parker lights stuck on
Australia
I have a LX470 that I recently replaced the heater core in. After reassembly I have a couple of electrical issues that I can't seem to figure out.
1. The parker lights are stuck on but they turn off when I unplug the side mirror folding switch
2. The windscreen wipers don't return to centre
3. The highbeam and blinkers no longer work. Normal driving lights work fine.
I thought I plugged everything back in correctly and can't see any loose plugs but obviously I have missed something. Has anyone experienced any of these issues before? I just want a bit of direction before I go pulling the entire dash out again.
I did also change the headunit while I was there but I swapped and alpine headunit for another Alpine headunit and didn't have to change the wiring harness. But I did remove some wiring from old tv setup that no longer worked.
Thanks in advance. Any help is much appreciated.
