Parker 821fr push-lok 3/8 -6 hose
South Oarnge Curtain
I BOUGHT THIS HOSE OFF EBAY BECAUSE I NEEDED ABOUT 100'.....SO I HAVE ABOUT 350' LEFT OVER. I'M USING IT FOR FUEL LINE AND TRANNY COOLER LINE AND WHATEVER ELSE TAKES OR CAN USE A 3/8" HOSE. CHECK OUT THE LINK FOR SPECIFICS. I'M SELLNG IT FOR $1.75 A FOOT AND IT'S LOCATED IN SOCAL 92653. IT'S NICE FOR USE ON RIGS AS IT HAS A FIRE RESISTANT OUTER SHEATH...IE 821FR
Parker Push-Lok Multipurpose Hose 821FR
THIS STUFF IS JUST GOOD TO KEEP AROUND THE SHOP AS YOU CAN USE IT FOR AIR, WATER, PATROLEUM PRODUCTS ETC...
IT USES PARKER PUSH-LOK FITTINGS THAT ARE COOL AS HELL! YOU CAN ALSO UE ANY BARBED OR PRESSED FITTING WITH SOME TYPE OF CLAMP.
The hose itself is fine for fuel, the "push-lok" fittings are not reccomended. they use the same synthetic rubber tube in there fuel designated lines. However you are correct and I...like the parker liturature do not sugest this hose be used on your rig for fuel. Thank you for pointing it out.
now buy some of this sweet sweet hose!
http://www.c-global.com/p4400_pdf/a10.pdf
Need to define all locations for use!!!
Trans lines...approx. 5 ft. x 2...
Fuel Lines?
Vacuum lines?
How many fittings does one receive if 50 feet is purchased?
I am in 92653...
Regards,
Frank:beer:
I, unfortunately do not have the fittings. So you would receive....0. however, I would be happy to share my homework on where to get the fittings you need for your specific application. There are quite a few guys that have these fittings.
Are you in Laguna Hills?
