For Sale painless wiring harness
maine
Painless Wiring Harness
New In Box
p/n 10101
picked it up for a conversion never happened. still in package.
275$ 400 new.
"This 21 circuit kit is our most widely used customizable chassis harness. You'll find that it's easily adaptable to almost any vehicle. This kit comes with a preterminated GM column mounted ignition switch connector. Included with this harness are the following parts; a GM engineered fuse block & Painless mounting bracket; GM turn signal connectors; pre wired plugs for the headlights & dimmer switch; and each wire is printed with the circuit identification as well as using GM color codes for easy installation."
Must post a price per forum rules
What were you going to use this for? Would this work for an FJ62?[/QUOTE]
Was going to be used for a 40. going to rebuild the 2f if we can free the pistons.
its a universal kit. so theoretically it would work it but you will end up with a gm style fuse box but a whole new harness to boot.
here are the specs from Painless' site.
" also KruiserK.. I will be in New York first week of Sept. I could save you the shipping if you buy me a beer somewhere in the city"
Number of Circuits:
21 Circuit - 12 Fuses w/ Horn Relay and Maxi Fuse
Harness Length: Universal
Fuse Type: Blade
Firewall Passthrough: Grommet
Color Code Based: GM
Circuit Designations: Printed on wire
Connectors Included: GM Steering Column Turn Switch and Ignition Switch, Dimmer Switch, Two Headlight Pigtails, 10SI & 12 SI Alternator, HEI Power and Tach and 20 Extra 56 Series Terminals for use with any Factory GM 56 Series Connector such as Headlight Switch, Wiper Switch or A/C Switch/Blower Motor.
This harness includes circuits for:
  1. A/C & Heat
  2. Accessory / Cigarette Lighter
  3. Backup Lights
  4. Brake Lights
  5. Charging
  6. Dome Light
  7. Electric Choke
  8. Emergency Flashers
  9. Fan Relay Activation Power
  10. Fused Power Source
  11. Headlights
  12. Horn (Relay)
  13. Ignition Coil
  14. Instrument Panel Lighting and Gauges*
  15. Park Lights
  16. Radio/Clock (Constant and Switched)
  17. Starting
  18. Tail Lights
  19. Third Brake Light
  20. Turn Signals
  21. Wipers
* Including Wires For:
Fuel Gauge
Oil Gauge
Tachometer
Temperature Gauge
Voltmeter
I am very interested in this for my 40. Let me do some research and get back with you. Would you be willing to ship?
