- Location
- United States
If you're looking to change your FJ62 over to a stick shift or to really do it right and go to an H55 5 speed I have the parts you'll need. Everything listed here came from a running 1987 FJ60. Included:
Bellhousing- bolts right up to a 3FE and either a 4 speed or H55 bolts right up to it. The bottom cover (hard to find these days) is there as is the release bearing arm and release bearing
Clutch slave cylinder with return spring and bracket
Flywheel with used clutch assembly
4 speed transmission with 38MM split case still attached. Shifters included. Wiring harness is uncut
Pedal bucket complete assembly
Driveshafts front and rear
Crossmember and rear motor mount
Steel transmission cover (no shift boots)
I will include all original fasteners- flywheel to crankshaft, clutch cover, tranny to bell, bell to engine, all hardware from both ends of both driveshafts etc.
Price $550. Buy a new H55 and make your FJ62 more fun to drive and better on gas. If need be I can remove the transfer case from the transmission for the buyer.
Located in northeast PA not far from either Rausch Creek or AAOA offroad parks. I will highly prefer to sell this setup to someone who can come and pick it up. Best to email me shmukter@pa.metrocast.net
