My first CEL on my 06 LC at 130k. CEL came on more than year ago with P0456, I erased code, came on for same code 6 months later, then one month with both P0456 and P0441, then a week, then every day. As everyone does, I replaced the gas cap with OEM, CEL back same day.
In the service manual, it describes how codes are trigged. I concluded that the most likely component to trig both P0456 (small leak) and P0441 (incorrect purge flow) simultaneously is the VSV at the intake manifold. I removed the VSV to check it on my bench, it did not seal 100% with a vacuum applied on a port, I applied 12 VDC to it, solenoid makes a light click and the valve did not opened. I blew compressed air to it with 12 VDC applied and it fully opened and sealed a bit tighter. Reinstalled it, CEL back after a week. I rechecked it on my and did not open with 12 VDC applied. Ordered a new VSV P/N 90910-12259, the new valve makes a much louder click, seals 100% when closed and fully opens when 12 VDC applied. Installed the new VSV, CEL did not came back on after two weeks.
If you get both P0441 and P0456, look at a defective VSV. Take into account that the valve can be intermittent like mine.
