P0401. gone ..2 details
Burnsville,nc.
tools i used; EGR valve:1 1/4" box wrench, # 7 reverse torx socket- egr studs
14mm socket; intake brace top, with extension to loosen lower nut
VSV: my left hand grab vsv connector, right hand, long shaft small thin flat blade screw driver; from pass. side, top of intake, place blade inside right side of the connector, wiggle and pull down with left hand.
made a bracket to relocate new vsv outside of intake.
i used the 12mm grounding bolt driver side forward, see pic.
