Couple days ago my 80 started to misfire violently at low rpm/speed from a stop. Code is for the cam position sensor (the distributor basically)
Replaced:
Distributor
Plugs
Wires
Crank position sensor
Throttle position sensor
Also did:
Seafoam through the intake manifold
B12 Chemtool in the tank
Next on the list is a fuel filter
Upon completing the distributor swap, I checked timing with a light, adjusted to 3 degrees with the TPS at 9. When I came back from my drive the timing had set itself back to 0
Next I advanced timing to 6, and upon coming back again it had advanced itself to about 10 degrees.
I don’t believe bad gas is the culprit, I have a tank of Shell 91 in right now
I’m running out of ideas here, only other thing I can think of besides the fuel filter is would be an IAC valve, which is unlikely, but I’ve read of guys that had this issue or similar and that fixed it
I’m just getting tired of throwing money at the thing
any suggestions?
Replaced:
Distributor
Plugs
Wires
Also did:
any suggestions?
