P0305 Coil
Easy... Third cylinder from the front of the car on the driver's side. Probably need a new coil pack.
Cool. JUs yank the engine cover, unbolt the the coil retainer and pull out the coil? Just pull lightly and vac out the hole afterwards before pushing the new coil in?
yep
That is correct. I just replaced my #5 coil pack and it was quite easy. Just do exactly as you said.
Cool! Done and I cleared the code with the OBD scanner. Runs like new again. Thanks for the support!
