Oz tent Tagalong and fox wing
Kamloops
I am coming to a crossroads and will be getting rid of my 100, lx479 and tundra. Importing a 99 hz77 from japan. Decided to move to Africa and take 3 months and drive Capetown to Sudan and back, but that is for another thread.
Most of the 3 months will be spent camping along the way in various campgrounds and game reserves, so we had to decide on the most appropriate setup. Talked a lot about an rtt, but given the weight up top (considering other gear we will be taking up there)and the fact we are taking our 1 yr old daughter (she will be 2.5 yrs old by the time we go), climbing up and down and still needing privacy, integrated living space and sun shade, we spring for the tag along. We will buy a rtt when we are settled in Botswana (this is where we will live) and primarily be for bush camping where we are up off the ground from animals in the delta.
some of the living luxuries will be transferred to the hjz77, i.e. onboard hot water, awning, tagalong etc, but so far testing the tagalong out on the 100 last weekend was a success. learned a couple things, i.e. looking forward to a bug room for the foxwing, perhaps one more extra panel would be a benefit for privacy/wind and trapping our daughter in to a more control space:)..
Photos are below... as a reference, we originally had the tagalong off the panel parallel with the passenger side of the 100, but it blocked our view of the lake and fire - so we put it to the only side of the foxwing we could, although it isn't mean to be on either end of the awning panels, just the two middle ones as it need pole support.. it is possible on the ends, just not as secure of an end post as there is nothing to secure the post to teh awning.
setup was quick, although instructions on the carrying case were poor. basically unfold it under the panel you want to zip it to on the awning, lift the front panel to the awning pole and slip it over the pole.. do the same on the other side. do the zipper across the awning which connects it to the tent. from there, pull the bottom out and peg it all around 4 corners. insert the horizontal bar and connect it to eh two bars that are at 45 degrees. add guy ropes as you need/want. lots of ventilation, room for three, although we had our double bed roll for my wife and I, and my daughter was in the crib that we had at the foot of the bedroll. the dogs slept outside :)..
the benefit of this over a rtt for botswana game drives and camping in the bush is that you can easily access the door of the vehicle if you are having animal problems.. the rtt is off the ground yes, but still need to climb down and then access (unless you have a sunroof that can be accessed)..
more testing to come, but i really like how all the sitting, sleeping, cooking, showering can be on one level and integrated in together.
Sounds like a fantastic adventure! Please do start a thread on the trip.
Love those bright orange guy ropes on your old setup. I need to go that route myself. Dark green rope at dawn and dusk is a bit tough... :bang:
Very trick setup with the room off of the foxwing. I'll be adding a Foxwing to my trailer shortly. You are giving me lots of food for thought.
Quick question about the Foxwing. Are you happy you went with the Passenger side version? I was thinking maybe the Driver side would be preferred because of the tire swing out.
Thread will be started - we are just doing the financial analysis of the business we would be buying. in the meantime, I am searching for a 1999 hj77 to bring over and will start once we get to 100% on the decision.. still at 80%.
the foxwing is terrific.. I was a bit disappointed with not being able to get a bug room to fit as they currently don't design one for this awning, however, speaking to OZtent in Salt Lake City, it is in the works. coverage 270 degrees is a wonderful thing in a downpour; you can continue cooking/cleaning/showering off various points of the truck as you've set it up.
you have a good point on the passenger side vs drivers side setup - the tire gets in the way. I have rigged up my hot water tank where the wheel well is under the vehicle (11 gallons and fully skid plated) and the shower head gets fixed to the spare tire mount. it could be put off the other side so its a moot point. either way, I might be inclined to do a single swing if I were to do it again.. although doing that would completely section off the one side of the awning.
a dual swing could allow you to do cool mountings off the inside of your bumper.. i.e. removable cooking platform, wash basin etc..
Ben I just picked up a Foxwing and so far am pretty happy with it. It's easier to set up alone than the ARB, although not sticking out as far means it's less shady if the awning's on the sunny side. But then it's shady on the tail gate, so... it's a little difficult to close the zipper bag, you really have to stuff all that awning up in there. But all in all a pretty decent upgrade.
A few of these ground tent threads have me thinking about those as well, could be a sweet setup. If you go this route, let me know so I can send you some adapter plates.. ;)
