Instead of the usual birf party, maybe there should be a bellypan party. Make a weekend out of it. ???;p
ding ding ding!!
I would love to have one of those...
Not to sound negative, but I'm with Landtank. The weight of the vehicle unloading onto a hard surface like a rock is much greater than that of it not even completely suspended by a jack.
I still love my IPOR. It protects so well. And I really love the added ground clearance.
The way you wheel, it might work better if your entire body was made out of 4 gauge steel.
You're not that far away from me though. If you want one, let me know, and it can be arranged.![]()
into it after the 4Runner sells!My body is way too far gone to save, not even worth it anymore!![]()
PM me a $$. I may be able to talk theinto it after the 4Runner sells!
i just wonder with heat build up under form tran,cat.
Your replacing a box piece of steel with a flat plate. Of course you gaining ground clearance. You just wrapped a piece of steel around that box cross member. You lost a lot of ground clearance doing that. Measure your clearance. You will see it is low. I will measure mine.Ebag333;3681235I said:really like the IPOR. I disagree however that it buys you any ground clearance that matters. The T-Case hangs way lower than the cross member, and you're measuring your extra clearance in quarter inches.
In 99.9999999% of all situations, if that extra clearance was going to make the difference, you were likely hosed anyway.
Since my skid plate is tucked up so tightly against the t-case (maybe even too close), it has at least as much if not more clearance as the IPOR does under the t-case.
As I said before, if I didn't go my own route and if Slee's new one wasn't available, IPOR's would have been my choice easily. IPOR's plate is a great product, just a bit too pricey for me, and didn't quite fit my needs/wants.
Did you have any other build pix?
i think it looks awesome! don't be discouraged by some web wheelers on here. I'm with you in that you build it, try it out and make adjustments as necessary. If it bends, you fix it. If it doesn't bend, you keep trying to bend it!
Creeper fo' sure needs one of those!
one more question though....
Is the T-case actually touching the plate? If it is, do you feel/hear any buzzing or vibrations?
