So I'm helping a friend with a 2UZ-equipped vehicle (it's not a 100 but I wanted to ask here since I know I'll get a quick response). It overheated during a drive around town enough to cause pinging/noticeable performance issues and throwing the christmas-tree of warning lights on the dash. He pulled over and had it towed to a shop. After it cooled, shop filled it up and he was able to drive it home but it used up about a gallon of coolant on the short drive home (but did not overheat). They diagnosed it as a leaking HG (no visible coolant leaks). Shop is telling him to just buy a new motor ($9.5k installed) which seems a bit overkill to me.
I went to his place tonight and ran a compression test - ~180 across the board and all within 10 PSI of one another. We also drained the oil - it was apparently changed a couple days before the failure. It does not look like new oil (fairly brown) but the viscosity seems good and it did not look like there was water in it. No metal shavings/sludge visible, so I don't think the internal damage was too great.
He's got a quote to purchase HG, timing belt (while you're in there), water pump, etc. and I offered to help him do the repair. I told him that doing the repair is a gamble with his time and the parts money, but it sounds better to him than 9K. To ease the pain, he has another 2UZ vehicle he can always pull the water pump and timing parts he bought new to use later.
As the truck sits right now, it will start up and idle/rev normally (sounds just like my 100 series of the same year, which is in good health), so I don't think the motor was irreparably damaged.
- Is my testing approach and reasoning sound?
- Can a machine shop check the heads to see if they warped?
- If they did warp, do you get them resurfaced or do you replace them altogether?
- What other items might need to be checked/replaced as a result of overheating?
