- Year
- 1993
- Vehicle Model
- 80 Series
- Mileage
- 305000
- Color
- Green
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.
New
Charcoal canister not OEM
Air filter
Plugs
Wires are reused and in good condition
Cap and rotor
New Toyota radiator
Aisin water pump
Belts
Starter denso
Reman Toyota alternator
A/C compressor Denso blows 46 degrees
Cleaned and flow tested injectors
Fuel filter
Oil 15-40 and OEM filter
Rebuilt power steering pump with OEM kit
High pressure line is gates
Trans lines to radiator and cooler replaced
Radiator hoses
Aisin blue hub fan clutch and new blade
Heat shields
Intake hose is original and verified to cracked leaks the system was smoke tested
Pair valve deleted and caped off plates installed on manifolds
EGR deleted and plated off at head and intake
Compression test done 160-170 on all cylinders
Valve cover reseal
Timing cover reseal, front main seal, oil pump oring with new torques screws and a new harmonic balancer torqued to 310ftlbs
Distributor o ring
Updated Idle Air Control Valve
Rear heater deleted
Heater control valve and hoses
New OEM O2 sensors and gaskets
The known issue is rear main seal or upper oil pan arch seal is leaking like usual not worth fixing yet in my opinion.
Exterior fender flares where painted black along with the hood and cowl. Doesn’t look terrible. This can be addressed I have a good painter if it’s an issue.
PNW truck so no rust issues. Has a ARB front bumper winch compatible.
Asking $14k if you have questions ask here for transparency. Thanks Wes
