With the 45, you could also go 4 door... That'd be super cool.
Check out this site for inspiration...
FJ | Gallery | FJ-44 | ICON
I don't want to spoil the party, but looking at the pictures, you are not really buying a Land Cruiser, but just a bunch of off year body panels and a questionable frame (the 40)
You can't go wrong with either of them because you sound determined and will make it work either way. The 45 will require more custom work to fit more than 2 inside comfortably. The 45 has a metal roof and the 40 is stock with the fiberglass roof...easy to fix fiberglassI have always wanted a 45, and we have more choices than you it seems, even in the US they are hard to find. Good luck to you, whichever way you go!
I don't want to spoil the party, but looking at the pictures, you are not really buying a Land Cruiser, but just a bunch of off year body panels and a questionable frame (the 40) or a burned out shell (45). And most of it you won't be using anyway.
That is not way to start a restoration. Like said before, anything can be fixed and some people do but you will have to start with something half decent especially in a country where parts are hard to find (if at all)
You will need a lot of stuff and from what I hear that could be a problem. Not only would it cost you a fortune, but you might have to fabricate stuff yourself. A project like this is like building house, you start with the foundation, And if either of these shells is the basis, you will run into serious difficulties.
I know you are enthusiastic and determined but don't let it blind you judgement. You say that FJ's are hard to find in Kenya, but I am sure they are out there. Maybe not now. Looking at the money you will have to spend to get either one on the road, you can also search in other countries and import. Maybe you should think out of the box. Don't you have a friend that is going to move to Kenya bring one with him? Any foreign companies with that might be able to help sourcing a good one. If registration is a problem, you could buy either one of them and use the numbers for what ever you find in another country.
I have done some major projects but I would walk away from these two, unless you need a source for parts.
I think the only thing on the 40 that you will find 74 is paper work. Guessing this is a 81/82. Only thing different than those years in the North America market would be the glove box door still being spring loaded latch instead of a twist handle. And of course it's a RHD. I think everything or most everthing on that 40 came originally on it. But it is missing many parts which would probably be much easier to find here. A lot of the parts missing could be found here aftermarket which is a lot cheaper than having to go OEM on all parts. Plus many parts are pretty easy to find used unless it was rare part to begin with. As for importing one form another country and switching paper work. In the US it either has to be imported legally or be chopped in half. Get caught switching VINs around not only would lose the vehicle but would be dealing with legal problems. I still think importing a mid wheel base 4X series would be the easiest way to go if parts are that hard to come.![]()
One concern with the 40 is it's legality in your area. I'd hate to see it rebuilt only to have a problem if someone realizes the body is a different age from the registration.
i say save some money and buy a diesel 42 from Auz. or somewhere in your country. one thats compete and drivable. the diesel is very easy to drive, a kid can learn, so your wife will be impressed with her new tallents and might not let you drive it !
Too much hastle matching and mismatching parts. Once time is gone we can't get it back.
Just my thoughts...
My ideal scenario is an 80 series drivetrain with a 40 / 45 body.
I can tell you that our importation laws are pretty messed up and it's not just that easy to get stuff in bcos it need inspections, etc.
I definitely will not swap VIN's. What I can do is use a VIN / Frame from 1 car and only transplant the body of another over this frame.
Guys I need your help...
How much will it cost in US$ to get:
all window glass
door rubbers,
window winders
door handles
wiper motor and linkages
full fj40 roof
lights
switches
windscreen drop down knobs
door locks
Any other items that I will need (ignore the engine, gearbox & axles)... I really want an 80 series drivetrain... or can I add the 80 series axles under the 40 / 45 series and get a coil suspension getting rid of the leaf springs?
I can then add on our import duties, freight costs, inspection costs, etc.
Thanks in advance.
For sure I am determined but I am also logical and do not want to throw good money into an empty hole. I know this sounds like a downer - but I guess there's more than 1 way to skin a cat.
I spoke to a specialist fabricator today who is damn good at converting FJ70's into safari wagons. They add 4 doors and elongate the body / chassis. Damn...my heart sank... they want US$12,000 for adding 2 doors!
$12,000 seems crazy. To stretch a 45 into a 4 door, you'd need 2 more doors, some filler pieces to go between the front and rear doors, a 40 roof (or a 45 stretched one), and a stretched tub. Even paying a guy $50 an hour, I can't see the bill getting to $12,000 to do that.
I have no idea on the logistics of importing stuf, but I'd also check out these places for body parts...
FJ Quad Cabs - Aluminum Replacement Bodies & Accessories for Land Cruisers, Jeeps& Samurai's (quality products)
40 series panels : Extremebends.com | Landcruiser Toyota Parts and EBI 4x4 Accessories (good local reputation and tons of stuff not on their site)
Bikersmurf - your description is pretty good on fitting the glass. I've seen this done a few times so know where you're coming from.
I think the secret of my build is to get as complete a truck as possible (right hand drive) and then rebuild it on home ground.
Naturally I will not take the engine / gearbox & axles unless I get a complete truck with the 1HDT and auto gearbox - and I think that's going to be fat chance!
My problem is going to be trying to trust someone to ship the parts (especially a private seller) as they will want the money up front.
We'll see... I have contacted a few ebay sellers to see what they have to say... Also being in Africa does not help because of the number of scams and people having bad experiences and getting cheated.
