Opinion needed - What to do with old OEM alternator? (2 Viewers)
Washington State
I left Sedona on my way back to Seattle last week and the battery light came on in Flagstaff roughly 1,400 miles from home. I assumed it was the alternator because the battery is only 7 months old. The only place that had an alternator in stock (Toyota included) was Auto Zone. Put in a new alternator and battery light was gone and all is good. Light has never come back and no electrical issues.
The funny part is the OEM alternator was tested at Auto Zone (several times) and tested good. There was a small amount of corosion on the ground post connection but it does have 240K miles on it. Should I turn it in for the $40 core charge? or is there a way to rebuild the OEM unit? If I can rebuild it for cheap its not really worth turning in the core. It spins freely but I do hear a small amount of what could be bearing noise.
Any opnions?
I lost an alternator 20 mi off the highway in the mountains last week. My alternator was only 3 years old. Turned out somehow my connectors had gotten fried and cooked my alternator. I just took my $40 from the core and called it a day.
Do you have a photo of your old/failed alternator? This is an example of a failed one, soaked power steering fluid from a leak from the hose and high pressure fitting:
Any opnions?
I’m in the process of changing out my alternator. When I have time, I’m going to see if I can fix my broken OEM unit.
It's really easy to open up and test the rectifier and regulator, like what other's mentioned brushes is easy and cheap fix for alternator. My 93 truck's alternator(OE) quit at 290k and all it needed is a set of brushes and tested strong after. You could also buy the regulator and rectifier if needed but the rectifier is the most expensive part besides the rotor and stator.
Get it rebuilt by a good starter/generator shop. Put it on the shelf. That's what I do.
Alternatively, you can buy a used 150A Tundra/Sequoia for $40-60 and rebuild that instead.
Thanks for the replies everyone, I think I'm just going to keep it and go through it for a spare when the AutoZone unit goes out.......hopefully not anytime soon
You know it will go out, I say get that alternator fixed and put it on the shelf or take it with you on a long trip. Just my 2 pennies.
Smart move..
DO NOT turn it in for a mere $40. No way. Rebuild that sucker yourself (not that difficult), and save it because that Autozone unit is gonna give up the ghost one day.
Yep. Mine came apart pretty easily. I guess the heat gets to the plastic.
I should have been more specific. I used a Sequoia alternator so needed to swap to a different connector. But yes the old one was pretty crumbly and needed to be replaced anyway.
