What is your on board air system of choice and where do you have it located? 2016 LC200 owner wanting to air down/air up and be able to use tools.
ARB compressor on Slee tray by brake master cylinder.
As a new ARB twin owner, will it run tools with the simple manifold or do we need an air tank as well?
Thank you! I will stick with my tool box/battery powered tools and go with the ARB twin.Won’t run tools well.
Also Consistently hear that even with the ARB tank (pretty small), air tools are still mostly a no go.
If you want air tools, a power tank can easily handle that...but then you’re lugging the tank and relying on special fill-up sources. Personally, I would not enjoy securing/filling/haulibg a power tank.
On the other hand re tooks... -With super long life, high power tools like Milwaukee...seems like air tools aren’t so alluring as they once were. My larger Milwaukee M18 is so crazy powerful, I’m almost afraid to use it on my cruiser.... (up to 1400# ...!), but thankfully has three power levels.
Mid sized it about perfect IMHO. Can’t remember ever coming close to running the battery even half way down with mid-size battery...and you can charge it using built in inverter if needed...
The unit on the left is the smaller of my 2 Milwaukee impacts (ignore the drill on right) and its top setting is more than enough if you're using proper impact sockets.
Don’t really need a tank for that use, based on what I’ve been reading. Only the manifold kit to mount the solenoids.Where is a good place to put the small ARB airtank?
The twin ARB is installed by the brake cylinder with the SLEE kit.
I cannot put the tank where the spare tire was as I have a fuel tank there.
This is for running air lockers and airing up tires.
You mean with the service line pressure?I wonder if I can reseat a bead without the air tank. Didn’t think about that. Wasn’t an issue to do it with it.
