I'm midway through installing my OME suspension (front axle in) with a U-Bolt flip kit. All the suspension parts are OME, the flip kit is Man-A-Fre. I know everybody puts jack stands under the frame and also blocks up the axle and takes the wheels off. I decided to try it with the wheels on. So I jacked it up and installed jack stands under the frame so that the springs were at full droop and the tires were just touching the ground. Then I proceeded to remove the springs. After reading a dozen or so threads on this procedure, I was fully prepared to do battle getting the pins, shackles and ubolts removed. Well, I was pleasantly surprised when all the nuts came off pretty easy, and everything just came apart with no hammering and no heating.
When I installed the new springs, they were about an inch below the axle. So now I had to decide whether to lift the frame a little higher or take the wheels off and lower the axle. It was about 10 pm on Saturday, so I just decided to postpone the decision. Well this morning, I had an epiphany: Just let the air out of the tires! So this evening, I gave that a try and it worked like a dream. I let the air out and the axle settled down onto the spring pins. The cool thing about having the wheels still on is I could roll the axle back and forth until the spring pins popped up into the holes. There was still about an eighth of an inch between the spring and the axle. I put the ubolt flip kit on and tightened up the U-Bolts (not torqued yet) which sucked the springs up to the axle.
Now my question. Is that all there is to it? If the spring pins are in the matching holes on the bottom spring perches is that all that is required, or do I need to worry about any other adjustment? I'll have it aligned when I am finished, but I would like to know if I need to check anything with regards to the axle alignment before I torque it down. It's going too easy so far. I'm getting paranoid.
