OME Susp. sagging answer
Sunrise, FL
What's up guys. I was asking a while back about my 85 FJ60 sagging towards the right and front with a OME suspension. I followed you all's advise and called ARB. I was running the right set up in the rear which is supposed to be CSOORA on the driver's side and CS004RB on the passenger's side. ARB's answer was that even tought I had the "right" set up on my TLC there are some TLC that the A and B set up does not work properly. As we know TLC 60's and 62's tend to sag towards the left, that's why leaf A is arched higher than leaf B.
I bought the CS004RA and installed on the passenger's side, and that was the issue. Problem resolved.
I will try to post some pics sometime this week that way you are able to see the difference.
Also I am posting this to thank you all for your sugestions, and for some of you that may be having the same issue here is your answer.
Thanks
