OME 2703 Coil Spring Alternatives
Panama
Hi All
I am looking for a more comfortable front suspension setup. The rig currently has OME 2703 (703´s) coil springs with OME 91005 shocks. I run a stock bumper. No plans for bull bar or winch.
Ride feels harsh in the front end.
The rear has 2722 coil springs and 61029 shocks. Feels nice.
Tires are 305/55 R20 on Toyota Tundra Platinum 20x8J wheels (+60mm) running 1 1/4" (32mm) spacers. Effective offset is +28mm.
The truck is a VDJ-200, 4.5 diesel v8, KDSS equipped
The trucks sits level with current setup.
Will swapping coils for 2702´s make a noticeable difference? any other brand spring/shock combo suggestion?
Thanks!
Tito
2703 springs are 50mm lift and to suit 100kgs of accessories. 2702 is 50mm lift and no accessories. Spring rates are 126 N/mm vs 109N/mm.
Thanks man, yeah the previous owner used those heavy load coils for whatever reason. I dont know.
Do you know the height? might look into #600 Eibach´s. Close to 109N/mm
Wondering if there is a more comfortable alternative out there. Other than 2702.
I have 2702’s on the front, 2722’s in the rear, no front bumper. While the front end is “firm”, it’s definitely not jarring. You might give them a shot🤗
OE Spring rate is ~87 N/mm. 2702 Free height is 430mm
