So here's the deal -
My brake booster took a dump on me and I need to replace it. No biggie (hopefully).
I also have a PO401 code I need to fix soon, as smog testing is coming up in a month or so. I figure I'll pull the intake plenum, replace the EGR VSV, clear out the TB to EGR port, clean out the carbon from the plenum and runners, change the plugs, replace the leaky valve cover gasket, blah blah blah....
I see a small amount of oil seepage from between the head and block as it sits right now. ~180K mi on original HG. No other signs of HG failure - yet.
I'm sure it's imminent and I should do it while I'm at it and my motor will blow up as soon as I put everything back together (<--- not pessimism - it's called time-hardened realism
), but it doesn't NEED to be done right now, and situations usually (always) end up way harder and crappier for me when I try to do PM and nip things in the bud.
So, if I wanted to tighten up the head bolts, is it as simple as putting zip ties on (one for the cam gear teeth and one to keep the chain propped up so it doesn't slip on the crank gear), pulling the cams, and snugging up the bolts?
Note that I'm not asking anyone's opinion on whether I should just go all the way and pull the head. Yes, I actually agree with you. It WOULD be better. But what is only a little more work in theory, means old, rusted, frozen, broken parts and extra weeks of downtime for good 'ol me (and others I'm sure). If I don't HAVE to do it, I shouldn't. I have cursed hands.
I guess you could say that if that's the case, I should leave the head bolts alone too, but humor me here....
Sorry this post is rambling. Here is the actual question: "So, if I wanted to tighten up the head bolts, is it as simple as putting zip ties on (one for the cam gear teeth and one to keep the chain propped up so it doesn't slip on the crank gear), pulling the cams, and snugging up the bolts?"
Thanks
- Jon
P.S. - No, I haven't done a compression test, in case anyone asks.
Thanks
- Jon
