Oily substance dripping on mud flap Solved
El Paso, Texas
Website
www.badlandsexpeditions.wordpress.com
After about two hour of highway driving and four hours of off road driving we stopped for the night .
I noticed an oily substance dripping down the passenger side rear mud flap.
Seem to be like engine oil but have no idea. No smell.
By morning, there was no more dripping and no sign of any additional dripping.
Nothing in the wheel well.
Pictures attached.
Could it be related to the KDSS?
I don't have any warning lights.
Thanks
Probably drove thru some oil. Get gas or go to an auto parts store? Think back.
The mud flap has fresh 'oil' tracks and what appear to be earlier tracks now covered in dust. If you backtrack the fresh 'oil' upwards where does it lead?
Any chance that it's fuel coming out of the filler area, aren't there some relief valves there?
I had the breather system serviced and cleaned by Overland Cruisers no leaks.
the liquid substance does not smell like gas.
Following. Are there any KDSS fittings or lines that route above this area? Very weird.
@mep1811 you really use your 200 for its intended purpose. The dust should make tracking down the source fairly easy if you can climb under the truck at night with a headlamp and flashlight.
Rust-prevention goo dripping downward out of a body drain somewhere? I seem to remember the rear sunroof drains terminating behind the rear wheel wells.
Nothing KDSS related in that area.
There are different pieces of metal that look like they have to be removed.
I haven't cleaned anything so it should show up when opened up.
Rear wheel seal? Is there oil on the inside of your tire getting thrown into the fender and leaking down the mudflap?
