I have been researching were to install an additional oil temperature sensor. The best solution seems to be to install a sandwich adapter under the oil filter. like this:
www.shopsaas.com
but those are expensive. Especially from Australia to Europe!!
I happen to have an old oil temperature sensor laying around from an old project. It is too big to install in a T fitting with the original oil pressure sensor location.
So I was thinking. There is also oil in the valve cover. It would be super easy to install the temperature sensor in the valve cover.... but would I get an accurate reading? I guess the sensor would in practice be reading the oil/air fumes next to the valves, but would there be a significant difference?
SGAP5-2415 Toyota Oil Filter Sandwich Plate
Genuine SAAS oil filter sandwich plate and adaptor bolt suit M24x1.5 Toyota 1HZ 1HJ 1KZ diesel using Z334 or similar full flow oil filters and requiring 1/NPT ports for aftermarket pressure and temperature senders and gauge accessories
