I want to install an oil temp gauge on the 12HT engine, but what is, beside the oil plug,a good place for the sensor?Is there an extra plug in the engine near the oil pressure sensor to install this?
I still want to check the oil pressure!To check the temp i need an other sensor.replace the factory sensor/plug.
Okay,where is the second one?The one for the pressure sender is the most backwards on my engineThere are two ports already there, one is not used
One is on the block, and one is on the cooler. They are only a few inches apart and on the same plane.Okay,where is the second one?The one for the pressure sender is the most backwards on my engine
