I have a 1970 FJ40 with a small block 350. I’m not sure of the year of the motor. I’m trying to find out the operating ohm range for the oil pressure sending unit. I can’t seem to find the answer anywhere. I’m new to the mechanic game so over explaining is welcomed.
Do you have any block information such as a casting number or anything to identify the engine, secondly the pat number of the oil pressure sending unit?
Many of the GM "old school" engines up through 1972 had actual oil that went to the gauge. I don't know what the FJ40 has for a gauge, but is it an electrically actuated gauge or is it an oil actuated gauge?
Ok, for a rough starting point, see if you get these results:
The Oil Pressure Gauge Needle Should Point to:
Left Line (Low, 0 PSI) when sender resistance = ~0 Ω
Middle Line (30, 40, or 50 PSI) when sender resistance = 30 Ω
Right Line (High, 60, 80, or 100 PSI) when sender resistance = 60 Ω
