Well, this happened twice; oil pipes popped and engine hosed down. I promised myself this is not happening a third time
I replaced my alternator in my LJ78 (1991 - 2LTE) with a new one. This is fitted with an oil vacuum pump.
At the same time, I also decided to fix all the oil leaks I could find. Happy to say that there are no more oil leaks (apart from the popping oil pipes)
The first time it popped, it pulled of the connector near the brake booster. I did not notice it until about 4 min after running the engine. Basically lost 2.5 liters of oil.
After adding a new hose clamp, it popped at the alternator connector.
Taking into account that oil was pumping out of the top hose near the booster, I take the vacuum pump is operating as expected and taking oil from the engine and pumping it through to the booster (?) Is this correct?
There is another electrical pump (I think) just under the booster that connects the pipe from the alternator to the booster. Can this be faulty? I have a red arrow pointing to it in the photo.
I have attached a few photos after the second engine bay cleanup.
Your wisdom will be greatly appreciated.
