It looks as though I have some broken spot welds on my 2F pan gasket now.
Will the F oil-pan gasket fit the 2F oil-pan?
Errr....Yeah. That did kinda come out funny.The spot welds that attach the lower plate onto the oil pan. There are like 6 spot welds. Anyway, I noticed oil collecting around the skid plate. I wiped down the entire oil pan, and watched it as the engine was running (wheels chocked, of course), and I see oil as the engine warms up a bit collecting between the oil pan, and the skid plate that is attached. I think that a spot weld maybe cracked inside, and as the engine oil warms a bit, it seeps through the crack around the spot weld. Its not bad, but maybe a drip every minute or so, but its bugging me. So, I may drop the pan, and see if I can weld up a crack or something. There isn't any rash to the pan from hitting something, but I don't know what else it could be. Its not coming from around the gasket, and I already changed the oil plug gasket thinking that was it.
I am back in my oil pan this weekend and am switching over to the one piece while I am at it. This time I may try hanging it on the engine side first and installing the bolts without the pan until the sealant goes off---then put the pan on, I guess I'll see if that works better
