Oil flow direction for HDJ81 AT
Coquitlam, BC
By looking at the Toyota EPC it's showing that the ATF flows into the left side of the rad then exits via the right side and into a loop before returning to the oil pan. (if you are looking into the engine bay)
I am in the process of hooking up a tru-cool before the radiator oil cooler.
Cheers!
Sent from my iPhone using IH8MUD
Cheers!
Did you mean like this? Anyway, I don't know if I can still trace mine and check if it's installed properly... the coolier is already in place and I don't know if the mechanic installed it correctly.. any tips?
It's been too long since I messed with this, I think if you get under the truck and track the upper hardline from the trans, that's your feed line, and the lower is the return line.
