Greetings -
having recently noticed that an oil leak has caused some heater hose softness, I've been thinking about a field repair that I once had to do in a parking lot. The small hose on the water pump that runs from the lower pump thats about 3 inches long, to a hard pipe that goes underheath the A/C that is an absolute PITA to field replace. Was wondering if anyone has replaced/bypassed the hard pipe 15777B with just an additional length of hose to the oil coller hard pipe. Seems to be the easiet soltuion, but there had to be some original reason for using a series of hard pipes and short connectors, but durned if I can puzzle out why.
The next question would be with the location chosen, would it be possible to find an oil resistant high temp silicone hose by the foot to make that one section. Other heater hoses don't seem to have the proximity to oil leaking areas to be needing oil resistant hoses as much, but I do have some leaks down low, and don't necessarily want to worry about them causing a soft hose again post replacement, and then blow out.
Can't puzzle out how to attach/imbed an image (don't have any social to link to and its been ages seen I posted a new message with images) but its the usual oil cooler hose routing diagram from the FSM which I have saved as a desktop image. If someone can post the secret handshake steps to post a local non web based image I'll put it up in a later edit.
Thoughts?
Glenn in Marana, AZ
Thoughts?
Glenn in Marana, AZ
