Hello Fellow Mudders,
I have a 2008 LC200 with 158K miles. I have noticed that my cruiser has been consuming about 1 quart (946ml) every 1000 miles. This started to occur after I replaced water pump, drive belts and thermostat at 143K. My dealer says that according to Toyota, it is "normal" for it to consumer 1 quart every 1000 miles. I do not see any leaks on the ground and the dealer says there are not visible leaks under the hood.
Since I have purchased the cruiser at 129K miles, I've been replacing the oil every 10K with Toyota 0-20w synthetic. I drive mostly local with many stop lights, wouldn't call myself a "lead foot" but I average around 12.5-13.5 mpg when I drive primarily local.
Any thoughts? I looked into the Cam Tower leak but was not able to locate any leaks on my engine.
Thank you!
David
Thank you!
David
