Is there a certain offset needed to fit the 17" wheels on a LX 570? I thought I read spacers were needed, but found other posts where it looked like there were no issues.
Thank you!+35 is a great offset. That'll cover just about every tire size you may reasonably want to fit to the LX, from 33s to 35s.
Compared to the going price of used rock warriors, this seems like a good option.Should be 2,650... but good question
ALPHA equipt — overlandandoutdoor.com - https://www.overlandandoutdoor.com/blog/alphaequipt-qxCvW
Looks good.
I like the trd pro tundra wheels…and heritage wheels from the land cruiser..:but I think the offset on those is set up for 31-31.5” tires.Almost checked out, but think I'll hold out for some used 18" Tundra wheels at 1/2 the cost. Maybe even get a set of lightly used tires thrown in.
There are definitely some cheap tundra wheels out there. The OEM 18" 5 spoke aluminum wheels supposedly only weigh about 29lbs and can regularly be had for <$200 for a set. But you might do a little tire shopping first. The cost of 17" tires vs 18" will close some of that gap between new wheels and used tundra wheels. And if you are wanting to go to bigger tires, the OEM wheels will need a spacer, once again closing that gap even more.Almost checked out, but think I'll hold out for some used 18" Tundra wheels at 1/2 the cost. Maybe even get a set of lightly used tires thrown in.
Are you selling your facotry set of BBS wheels? Is this the 8,349th time someone has asked?I decided to give the Alpha Equipt Commands a try. 17x8.5 +35mm offset and about 26lbs. I am liking the fitment much better than the KMC Bully OLs I first put on(+18mm offset). Mounted the OE TPMS in the protected valve spot and the APEX Engineering valves in the other valve location.
LOL, close.Are you selling your facotry set of BBS wheels? Is this the 8,349th time someone has asked?![]()
