Official ONSC member buying/selling thread (4 Viewers)
I also have a used mini truck windshield for free. This and the winch cable are getting tossed soon if no one wants them.
I can use the windshield if its still available
Anyone need a solid cowl and windshield frame from an mid-60s FJ40?
Make a fair offer.
ISO - 40 series compatible sheet metal. I'm getting ready to try my hand at welding in some patches on the old dirty girl. Any old Toyota sheet metal would be ideal. Obviously I can go buy some new stuff but everything I've been told is that similar year OEM panels would be best. Anyway, I just figured I would check...
Thanks!
Thanks!
IMO new metal is easier to weld in than old. Who said similar year oem panels cut up to serve as patches were better?
Misc conversations with misc people / body guys / etc. :)
It's possible I swapped the word "cheaper" with "better" in some of those conversations. I just know that recommendation was offered more than once. And if someone was getting ready to toss something, it might work nicely for my purposes...
Nevertheless, I'm open to suggestions. Do you have a preferred spot to get new metal?
Around you I don't know too well, but if you're near an Alro, use them.
Or if you only need small pieces or are lazy, order from coremark metals. I’ve used them before and they ship quick.
Justin.
Ryerson and alro in Greensboro would likely have what you need. Both around triad farmers mkt off 40/sandy ridge area. I assume the plant in 421/77 does not sell/distribute from that location.
Alro has an outlet location with scraps n drops off s elm Eugene just south of 40.
Also if it was of if Interest I’m sure you could pilfer sheet metal off my 80. It would be 30 yrs newer and painted. Not sure how composition or thicknesses compare but your welcome to it if it helps.
*All Sold*
Free FJ60 stuff, pickup in Matthews
  • Front seatbelts, gray
  • Interior grab handle
  • Window crank, gray
  • Original inspection lamp
  • Side mirrors (need refinishing)
  • AC idle up pod
  • Original radio brackets
  • HVAC surround, gray, one crack on top left corner
  • Set of side reflectors (fronts are NIB)
  • Set of shock bushings (new oem)
  • Misc drivetrain bushings and pinion deflectors
  • Rear heater hard lines
  • Front chrome hub covers
  • 85+ clutch slave cylinder
  • Used oem ignition rotor
  • Coolant temp sensor
  • Driveline fill/drain crush washers
  • AC drier
  • OEM starter (needs rebuild)
  • PS pressure line
  • Oil pan gasket
  • Crankshaft pulley nut and woodruff key
  • Battery hold down
  • Rear wiper arm
  • Pass rear bumper end
  • Interior sill wiring cover
  • AC idler bearing and bracket
  • Random MTX 4-channel amp (working when removed)
  • 2” bulk exhaust pipe with clamp
Any part outs close to Raleigh?
Wtb:
1. 80-series washer fluid pump(97 lx450)
2. 80-series muffler
3. Drivers side window motor/regulator
4. Probably something but can’t remember.
5. Rear bumper corners and I suppose center section for a champagne lx. (Mine melted from exhaust)
Wtb:
I think I have 1,3, and 4.
I have NIB resonator but not muffler
1.5 hr west. Madison Nc
For those of you who want to be able to snatch your tow rig and trailer out of a mud pit, I have a new Warn snatch block rated for 36,000lb. Brand new, never used. SOLD
  • jynx
