This beautiful 2000 LX just pulled in for some restoration work. It has 109k miles on the clock, in great condition. It was own by a doctor in its previous ownership. The truck is in very good condition, but it is still a 20 years old truck. Due to age, we are going through the vehicle and replace any parts that are worn or for the purpose of preventive maintenance. The goal is to bring the truck back to sound and reliable condition to eliminate the possibility of breaking down as owner will be taking the truck anywhere off the beaten paths. Owner want the peace of mind that he can enjoy the vehicle for the next 100k miles with no worry or 2nd thought taking it to places. And to do it right, only Toyota parts or OE Toyota supplier parts will be used. As for fluid, we are using Eneos Japan synthetic fluid, Mobil, and Toyota coolant.
I replaced transfer case fluid, front & rear diff fluid, flushed transmission, replace AHC fluid and power steering flush about 3 weeks ago. Eneos full sythentic fluid were used. For power steering flush I use Mobil DTE-24 and add At-205 to replenish lost plasticizer in the seals to prevent leak. Steering rack is in great condition with no leak or torn boot or play.
There are few areas of the 100 series that fails dues to age such as ignition rod, heater T, brake booster and main fuse box which will leave driver and passenger stranded. Since the mileage is fairly low, we will look into the possibility of replacing the brake booster and main fuse box once the 1st phase of restoration is done. For now, we are replacing the following parts as preventive maintenance as any parts that fail as I dig into the truck.
1. 130 amp Starter and connector
2. Alternator and connectors
3. Radiator
4. Radiator Hoses and all heater hoses with the infamous heater Ts
5. Thermostat with gasket
5. All vacumn hoses, pcv hoses and valve
6. Spark plugs
7. Fuel filter
8. Air filter & cabin filter
9. Ignition bracket rod
Repair needed:
1. Replace both CV axles along with all gaskets & seals ( torn boot and hairline cracks observed )
2. Replace valve cover gaskets and spark plug tubes seals ( valve cover leaks )
Water pump & timing belt were replaced 10000 miles ago, so we are not replacing those.
3. Radiator
6. Spark plugs
7. Fuel filter
Repair needed:
