OEM TPMS gaskets
CA
Does anyone know where to get the new rubber seal to transfer the factory TPMS to another wheel?
What I searched is a xtra seal 17-20216AK
it has a new barrel, washer, gasket. Does toyota make something like that?
Thanks
Toyota does offer a fitting kit, part number 04423-33030
Thanks, that's great
Do you know if it is usually OK to take the OEM sensor and put it in aftermarket wheels? I usually just bolt them on torque them but just about most of the time the sensor could not rest on the wheel's barrel, but they usually still work fine that way.
Generally yes, as long as the sensor doesn’t push too hard on the wheel barrel.
If it’s sticking out away from the barrel the big risk is getting snagged during tire mount/dismounting. Otherwise it can handle the centrifugal forces just fine.
