OEM PARTS STILL AVAILABLE FROM TOYOTA
Unimogguy
VA ➡️ CO
Does anyone know if there’s a current’ish list of OEM parts and part numbers that are still available from Toyota for our FJ-45’s? I remember seeing a thread somewhere here with them but for some reason after 10 different search terms and scrolling thru 70+ pages I can’t seem to find it. 🤦🏻‍♂️🤯🔫
If there’s not a thread maybe we could all post OEM parts and part numbers that we know are still available here in this thread?
If we are able find the thread if someone could post the link it here that would be very helpful!
An even better idea is if a MOD could put it under the “Owners post here” thread in the section that always stays at the top!!!
Here’s what I’ve found so far…
As of 3-11-25 everything listed here was still in stock at the dealership.
16400-49356 —-Radiator
90950-01222 —-Hole Plug
90950-01006 —-Hole Plug
12151-61010 —-Oil Pan Gasket
23100-61011 —-Fuel Pump Assembly
75451-90300 —-Rear Body Ornament
81240-90300 —-Roof Lamp Assembly
82670-30020 —-Junction Block Assembly
90368-41002-3 —-Tapered Roller Bearing
90312-55010-3 —-Type V Oil Seal
90368-38003 —-Tapered Roller Bearing
90365-470070-K —-Still trying to figure out what this is
90311-74029-J —-Still trying to figure out what this is
42181-60060 —-Differential Carrier Gasket
90311-38047-DP —-Type T Oil Seal
33030-60450 —H55F 5 speed Transmission
81980-20040- Flasher
16400-49356- Radiator
13101-60011- STD Piston
I’ve got a bunch more part numbers that I’ll input later after checking availability. Most of these are stolen from other peoples build threads. Where I saw a part number and saved it for later.
